| Posted by hj on June 21, 19100 at 09:37:46: | |
| In response to Re: Installing a Stainless Steel Undermount Sink | |
The caulk is not designed to cement the sink to the top. The sink should be installed in the cbinets in such a way that its top surface will meet the bottom of the countertop. then after the counters are installed the caulk seals the joint between the two. : I am having difficulty geeting a bond between a stainless steel undermount sink and a granite counter top. I have cleaned each with denatured alcohol, sanded the stainless to roughen the surface and am using a 100% silicone caulking made by GE. The sink has been clamped to the counter top for 48 hours, but still not a strong bond. Basically the silicone is not bonding to the stainless, but bonds fine to the granite. Any suggestions on what I am doing wrong or what I should try instead.
| There are none. |
