| Posted by hj on June 10, 19100 at 10:35:29: | |
| In response to Re: Are there alternatives for the wax seal? | |
It depends on your situation. If the toilet flange cannot be secured to the floor and it can move, then using a wax ring may not be the best way since tightening the bolts will just squeeze the wax out and the flange will be in contact with the bowl and will leak. When that is the case, then a rubber ring is preferable since it just seals tighter as the flange approaches the blow. : Are there any other type toilet seals that can be used in place of the wax seal? If not what is the best type wax seal?
| There are none. |
