#1
Hello all,
I am in the process of a complete remodel of my 3/4 bath. I have encountered an unusual PVC Y fitting. It is a 7 1/2 long, 3x4x2 y. The 4" section connects to the old 4" cast iron but it is labeled Permafit and has the # 45174 on it. Is this a special sleeve or a special Y fitting? I googled Permafit and Colonial Engineering and could not find anything. Extra space is nonexistant so I must find a replacement. Please advise. Respectfully, Joe |
#2
Joe,
I also encountered an unusual fitting in my bathroom remodel. You can try looking up the fitting on a manufacturer website like Nibco - www.nibco.com, they make plastic fittings. I found that to actually buy the fitting, I could not go to HD or Lowes, I had to go to a couple of pipe supply stores until I found one that did enough volume to stock the part I needed, a 4" elbow with low heel vent inlet. In my area, Ferguson was that store - I think they are a nationwide chain of plumbing supply houses. If you take the fitting into the store, they may be able to help you. This is definitely one area where the service at a plumbing supply house is worth it. Plus, they may have doughnuts if you go early enough. good luck, Jason MacLeod Last edited by Terry; 12-26-2008 at 01:47 PM. |
#3
Could you post a picture of the fitting?
| Bookmarks |
| Thread Tools | Search this Thread |
| Display Modes | |
