Terry Love's Plumbing & Remodel DIY forum
Go Back   Terry Love's Plumbing & Remodel DIY forum > Remodel Forum
Reply
Thread Tools Search this Thread Display Modes
  #1
Old 01-17-2005, 07:12 PM
Lou Lou is offline
DIY Junior Member
Default sewage ejector
18 x 30 basin w/1/2 hp pump top of lid to waste line connection is about 4ft.,there is a toilet,shower,basin,and washer all tied into a 2in vent line that runs all the way to the roof,the toilet is the closest fixture to the basin about 4 ft away.Everything drains very quickly and the toilet flushes well.My problem is that when the pump cycles (only 5 seconds) the water in the toilet moves and this evevtually lowers the water level in the toilet.How do I fix this? Is the pump to powerful, the vent to small? Someone told me to drill a 3/16 hole 2 inches above the pump discharge inside the basin to offset the suction created by the pump. Thanks for your help ,great forum and website.
  #2
Old 01-17-2005, 08:40 PM
hj's Avatar
hj hj is online now
Moderator & Master Plumber
Default pump
In the first place the pump should not cycle that often so you have a problem there. Second, if the toilet is vented properly, then the only way the toilet level should be affected by the pump is if the water level in the pump is getting too high, i.e., within an inch or so of the floor level or at least higher than the pipe coming into the pit from the toilet.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
all rights reserved, Love Plumbing & Remodel, 1992-2009
