Verdeboy said:
I'm supposed to show someone how to use and maintain a pellet stove, but I've never used nor maintained one. Can anyone make me look smart here?
I've had mine for over 4 years now. What do you need to know exactly?
Here are some tips:
1. Only use premium pellets
2. There are several ways to light one if stove doesn't have starter.
3. Empty bag to fill up hopper up to capacity. (usually 40 lb bag)
4. Flu should be cleaned as with wood stove. (buy flexible rod and brush from dealer)
5.Once a year: Open door/panel where electronics are and very gently vacuum circuit boards/controls etc with
shop vac or regular vac with hose)
6. Only use qualified Pellet stove technicians. These are complicated devices.
7. Don't freak out if the hopper "screw" feeder jams on occasion. It happens
even on the best units available.
8.if the stove doesn't have a starter-gel starter is available
9. If hopper dumps too many pellets and extinguishes combustion, simply lower the setting.
10. After lit-leave it alone. When turning stove OFF the fan will continue to operate for 15-20 minutes. This is normal-safety feature.
11. Ash pan does NOT need to be emptied daily. I only empty mine about once per month. You may need to do it more frequently.
12. Stove is equipped witha "pull rod" that scrapes some internal ash that you cannot get to.
We have another pellet shortage this year. If you can afford it-buy an entire pallet. I buy around 10 bags at the time for storage reasons.
When pellets are available-
buy-buy-buy before you need them!
If you don't keep a good supply-you will be spending some chilly nights!
Walmart has lowest prices-around here anyway. Dealers in many cases carry better pellets.
You will pay 1-2 dollars more.
"Low ash" is key.
Pellet stoves create about 96% less pollution than standard wood stoves.
I am not an Expert-Follow instructions/dealer advice. Find "Wood Pellet Institute" for reliable links.
Hope that helps.
Mike
