Terry Love's Plumbing & Remodel DIY forum
Go Back   Terry Love's Plumbing & Remodel DIY forum > Toilet Forum discussions
Reply
Thread Tools Search this Thread Display Modes
  #1
Old 01-05-2005, 11:27 AM
Terry's Avatar
Terry Terry is online now
Forum Admin, Expert Plumber
Default Porcher Veneto toilet repairs
From Gordon by email:
I am trying to replace the piston assembly on a Porcher Veneto.
I have the replacement piece but I cant figure out how to get the old
piece out. If you look at the diagram at
http://www.porcher-us.com/pdfs/porcher/parts/Parts_815.pdf
I have parts 4 & 5 removed, but I cant seem to get part "6" unscrewed
from the tank housing. It's loose but will not come out? There is
obviously a nut on the other side but I cant get it free. How do I
unscrew this bugger? Is there a tool I am missing? Do I have to remove
the whole tank to get this out? I have the replacement pieces and it
looks like there is a nut (unnumbered but is on the diagram) and a
gasket (#7)
Yeesh, I am longing for the old flapper days. Did I get a lemon in this
porcher it has only been in for less than a year....
Obliged for your help!
gordon
http://www.e-onlineplumbingparts.com...er_toilets.htm
http://www.plumbingpartsdepot.com/porcherveneto.pdf
  #2
Old 01-13-2005, 05:37 PM
Plumber2000's Avatar
Plumber2000 Plumber2000 is offline
Hi
One piece toilets, never really liked them, some have a better setup on there, and some don't, I have not worked on these ones, wish I could tell you what need to be done, only thought would be to call manufacture if you have there # and ask them.
__________________
Plumber for 20+years
  #3
Old 01-13-2005, 06:45 PM
Do you know if the tank is removable, to me it looks like you can't take the tank off, have you tried to push down and turn, if only there was a better picture of diagram, any chance you can post a picture of th inside of this tank, like to take a closer look.
__________________
  #4
Old 04-27-2005, 10:39 AM
RobW RobW is offline
DIY Junior Member
gordon
Did you ever get this fixed? I've got a Porcher Veneto that's about 2 years old and also needs the valve replaced. What's the deal with these puppies? If they were cars, I'd think they'd be recalled
TIA,
Rob W
  #5
Old 02-07-2007, 03:19 PM
tmcauliffe tmcauliffe is offline
DIY Junior Member
How does the upper valve housing come off the assembly? Is it the two tabs on either side. Also, did you ever get the lower valve housing off? Finally, where did you get the replacement parts. TIA.
  #6
Old 03-31-2007, 07:54 AM
sammysson sammysson is offline
DIY Junior Member
Thumbs down veneto- Getting rid of mine-
I have 4 of these toilets, they are nothing but costly with continuous maintenence. the piston just pulls off once you ave removed the upper portion, I have to replace this once every 6 months at a cost of $30 each, after 3 years i now must replace all the valve membranes at a cost of $18 each. The problem is the silicone gaskets which fail to seal after a while. I am planning on replacing all of them. However thet no longer sell just the gaskets. I figure I have already bought a new toilet with all the replacement parts. Additionally the lost water from the run through when the gaskets fail drives me nuts.
  #7
Old 09-12-2007, 05:17 PM
ha1976 ha1976 is offline
DIY Junior Member
Default Porcher Veneto Parts That Wear Out
I got the three Porcher Veneto toilets in my house because of the fine European look, not knowing that the 2 parts that normally wear out are not easily obtained in this country, yet widely available in Europe, made by GroheDal. The shut off membrane (GROHE 4375800M), also called "membrane assembly 83086.00.000" or "diaphragm gasket" normally lasts up to 5 years and can be easily replaced by unscrewing the large white knob of the supply tower; the discharge piston (GROHE 43544000), also called "piston assembly 83084.00.000" or "flush valve" lasts longer, but is a source of water leakage due to the deteriorated silicone seal. Both can be obtained at a fair price from Guillen Enterprises in Miami, FL, and the online service is very professional. Once you have a supply of these two parts in the house, your Veneto toilet will continue to function well while adding an elegant esthetic touch to your residence.
  #8
Old 09-17-2007, 03:32 PM
matt c matt c is offline
DIY Junior Member
Just an update for all who have leaking porcher veneto toilets.. I have a 11-year old porcher, so I called Porcher at 1-800-359-3261 in regards to my leaking veneto.. They transferred me to a technical support specialist who said I either needed a new flush piston, aptly referred to as a piston assembly 83084.00.000 by ha1976, or a new membrane. They sent me both..
My leak was due to the piston assembly (flush piston). The piston sits inside the upper valve housing. The upper valve housing comes off by twisting the upper housing counter-clockwise. When you lift the valve housing out of the tank you will see the flush piston extruding from the bottom of the housing. The flush piston can be pulled out of the housing.. Yes, it just pulls out. And you just push the new piston in place.. Secure the valve assembly back into the tank by rotating the housing clock-wise.. By the way, my veneto has two clips on the housing which secure the housing in place.
Hope this helps. And thanks to everyone on this site who gave me enough info to fix my leaking veneto.. Cheers to the tech specialist at Porcher who helped me too.
  #9
Old 10-20-2007, 04:57 PM
Dennis F Dennis F is offline
DIY Junior Member
Quote:
Thanks to 'HA1976' for the excellent information!
Our Porcher Venetto was installed about 10 years ago and has proved to be an exceptional fixture. The flush siphon/valve is very well designed & strong. However, we have hard water (high caco3) sod I replaced the parts as a precaution. No seeps and No leaks.
I did find the parts easily available in France/Germany but did not know the Grohe order numbers for these inexpensive two replacement parts! American Std., the parent company, supplies parts, but they're pricey. THANKS for the Grohe order numbers !!
Dennis
  #10
Old 05-29-2008, 02:13 PM
Andy009 Andy009 is offline
DIY Junior Member
Smile Porcher Veneto toilets parts
I'm soooo glad I found this forum! thanks to all of you I was able to find the parts I have been looking for.
The water tank leak and the shut off valve problem will soon be fixed once my parts arrive.
thanks again guys!
Andy -
  #11
Old 07-30-2008, 04:03 PM
waldo123 waldo123 is offline
DIY Junior Member
Default porcher veneto
I've got 2 porcher veneto II's, both about a year old.
The flushing handle sticks down on both, when flushing, unless you flush it "quickly" (push it down fast and don't hold it down long). Is this an adjustment issue or a porcher veneto personality trait?
Also, the slow close lid on one of these puppies is now a fast slam. Again, another adjustment item?
  #12
Old 08-11-2009, 05:12 PM
edk edk is offline
DIY Junior Member
Smile porcher veneto parts
I've had 3 Porcher Venetor toilets for 9 years. I LOVE them. They are great and have been maintenance free for 9 years. I now have one that requires the membrane to be replced cause I was cleaning out the inside and accidetally ripped the membrane. The parts are easy to take out, clean and replace. Much easier than the old fashioned toilets with the flapper and chain.
Thanks to this site and the posts, I found where I can purchase them at a resonable price, 10 for $10.95 (membrane) at **********.com. The Porcher is now owned by AmericanStandard, and buying parts from them is ludicrous. They're expensive and take forever to ship.
I am however looking for a parts conversion from Porcher to Grohe, since Grohe makes the Porcher parts. Does anyone know where this can be found? I'd like to have on hand a few spare parts like the gasket. Thanks
  #13
Old 08-15-2009, 09:05 AM
Vikki Vikki is offline
DIY Junior Member
We have an old Porcher Veneto which has served us well, but recently it started to vibrate and shake. If I wiggle the upper valve housing, I can stop it. I'm not sure if the gasket is the only thing I need to replace or if I need to replace the whole piston assembly. Any ideas? Also, does anyone know the Grohe part numbers for these?
Thank you very much!
Plumber Vikki
  #14
Old 08-21-2009, 09:00 PM
edk edk is offline
DIY Junior Member
Default Porcher Veneto parts
The best price on parts is from **********
Grohedal parts are cheaper than then Porcher part numbers
Grohedal
38029PIO complete fkush valve assembly
43544 piston assembly
43745 gasket
37092 water control assembly
43733 membrane (but from ********** a package of 10 is <$10, whereas at American Standard parts, they charge you $19.95 for just one
Porcher Veneto part Numbers from American Standard
83081.00.000 complete flush valve assembly
83084.00.000 piston assembly
83088.00.000 gasket
83082.00.000 water control assembly
83086.00.000 membrane
This site won't let me upload the tech spec sheet
  #15
Old 08-21-2009, 09:01 PM
edk edk is offline
DIY Junior Member
The best price is from the web site (do a search) for Home Center, but all one word.
  #16
Old 09-15-2009, 12:10 PM
innkeeper@willows-inn.com innkeeper@willows-inn.com is offline
DIY Junior Member
Default Thanks for your help
Thanks so much for this forum! I have been at a loss to figure out why my venetto leaks. It looks like the gasket on the piston assembly has a knob on it that allows water to leak through. I can't see how a new piston assembly will change that, but I'll give it a try. I have used Guillen out of Miami once before, with very good luck.
  #17
Old 10-03-2009, 11:50 AM
Guest Guest is offline
Questions from readers
How is the flush valve replaced with the plastic liner in place?
When the cartridge is spun out, how do you thread the new one in place with the liner there?
Texas
  #18
Old 10-03-2009, 02:24 PM
serglo@sbcglobal.net serglo@sbcglobal.net is offline
DIY Junior Member
Gordon did you ever replace the gasket,if so could you tell me how.
Thank you
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
all rights reserved, Love Plumbing & Remodel, 1992-2009
