Terry Love's Plumbing & Remodel DIY forum
Go Back   Terry Love's Plumbing & Remodel DIY forum > Remodel Forum
Reply
Thread Tools Search this Thread Display Modes
  #1
Old 01-05-2005, 09:13 AM
Not a plumber Not a plumber is offline
DIY Junior Member
Question Rough in dimensions?
Hi,
I am in the process of remodeling a bathroom...I have a few questions about rough-in heights.
I would like to know:
- the heights and spacing for sink h/c supply lines and for the drain...not sure exactly what the sink will be (pedistal, base cabinet or other), but I think a pedistal would have the tightest dimensions - so that's what I will go with.
- the height and spacing for the shower h/c supply lines. The existing tub will remain (probably have it reglazed), when the lower bthrm is remodeled, I will change out trap to pvc, unless it is copper (like the venting).
- the height for the toilet supply line. I had read somewhere me that the distance off wall for the toilet flange is 12"...but is that after finish, after sheetrock or off stud.
Thanks for any help.
  #2
Old 01-05-2005, 10:40 AM
jadnashua's Avatar
jadnashua jadnashua is offline
Moderator, but not a Pro
I can help on the toilet! The 12" is from the finished wall to the center (bolt holes) of the toilet flange. The offset for the toilet water supply does have a standard, but is dependent on whether you have a standard toilet! FOr example, I've installed several Toto models (highly recommended) that require the water to be further from teh center line than "normal" because of the shape of the fully faired base.
As to the other stuff, the supply lines for say a sink should account for the fixture that you are going to use - say if the faucet has attached lines, you don't want to have to try to extend then, and you don't want them looping all around. Also, you still want to be able to get to them, so you don't want them too high up, either. SO, while "normal" has its place (and the toilet flange is one that is pretty much truely standard for the vast majority of items), it sometimes depends on the actual stuff selected.
For a shower valve, if the owner was 6'6" tall, you'd want the shower head higher than normal (or adjustable), and you may want the valve higher, too. For a tub/shower combo, if you wanted to adjust the thing while sitting in the tub, you wouldn't want it too high. The tub filler needs to be a specified height above the rim of the tub, but other than that, some like a waterfall, even ceiling mounted!
One of the pros can probably give you some "standard" values, but I've found there is a lot of lattitude, and standard may not work with the specific stuff you select to install.
__________________
FWIW - Don't try to buy a phone from Nokia on-line
  #3
Old 01-06-2005, 06:09 PM
Dale's Plumbing Service, Dale's Plumbing Service, is offline
DIY Junior Member
Default rough-in measurements
you can go to your public library and get a beginners book on plumbing dimentions. also you may find it on the web. If in doubt buy all your fictures and install as per manufactures recomendations.
  #4
Old 01-10-2005, 09:33 PM
DIY Junior Member
Quote:
LMAO...what a dopey answer.
I came here (the web) to avoid going there(the library).
I thought the title of this forum was " Where homeowners get advice on how to plumb."...not "...go find it yourself..".
  #5
Old 01-11-2005, 07:37 AM
hj's Avatar
hj hj is online now
Moderator & Master Plumber
Default dimensions
Sometimes our best help is to tell you where to find things for yourself. But since you want the "Cliff Notes" version, if you are even considering a pedestal, then you have to decide on it first. If the pedestal has the entire backside cut out then the drain height is not important, but some have a formed recess for the trap and for those the height is very critical and you must have the manufacturer's drawing to determine the correct height. Too high and you will not be able to make the connection. Too low and the trap will not fit into the pedestal. For everything else, except the distance of the toilet opening from the backwall, (usually 12" from the finished surface), and the distance of the toilet opening from either side, (15" minimum), it is more or less a personal preference determined by the statures of the users.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
all rights reserved, Love Plumbing & Remodel, 1992-2009
