Terry Love's Plumbing & Remodel DIY forum
Go Back   Terry Love's Plumbing & Remodel DIY forum > Remodel Forum
Reply
Thread Tools Search this Thread Display Modes
  #1
Old 12-19-2004, 09:33 AM
bross123 bross123 is offline
DIY Junior Member
Default Hot Water Recirculation
Hi,
I need some advice on:
1. Pump size and a good manufacturer/model
2. Return pipe size and type of pipe (will pvc do OK?)
3. Is pipe insulation required
This is for a residential hot water recirculation system which has copper pipes.
I have 3 bathrooms, the farthest is about 70 feet from the Hot Water heater. I would like to run a recirculation system to save water and to get the hot water faster.
Any help/advice would be greatly appreciated.
  #2
Old 12-20-2004, 07:31 AM
hj's Avatar
hj hj is online now
Moderator & Master Plumber
Default hot water
1. almost any pump will work.
2. ANYTHING but PVC. It will get soft and burst when it gets hot.
3. insulatiing the lines will help reduce your power bills and add to the life of the water heater.
  #3
Old 12-20-2004, 07:36 AM
DIY Junior Member
hj,
Thanks for the info on the PVC pipe. What size pipe and pump do you think I should install?
  #4
Old 12-20-2004, 08:11 AM
jadnashua's Avatar
jadnashua jadnashua is online now
Moderator, but not a Pro
Your return line should probablly be the same size as the supply line. On the pump, make sure you get a bronze one (costs a lot more than the steel/cast iron), as it is required for potable water applications. My guess is that a TACO 007 would be sufficient. YOu could check out tacohvac.com web site and see what they use in their kit called D'Mand, then make your own choice. Note, I'm not a pro...
__________________
FWIW - Don't try to buy a phone from Nokia on-line
  #5
Old 12-20-2004, 04:01 PM
hj's Avatar
hj hj is online now
Default hot water
A stainless steel case pump will probably be cheaper than a brass one, unless you can find one of the small brass ones. The pump size is immaterial since you just want to keep water moving and a larger pump could create a high velocity which could cause pipe erosion. All you need is a 1/2" return line, but be sure to install a check valve after the pump before you connect back to the water heater.
  #6
Old 12-20-2004, 06:15 PM
jadnashua's Avatar
Taco makes a circulator with a built-in check valve (it's relatively new). One less thing to install. Not sure if it is available in brass or stainless, though. Check their website tacohvac.com
__________________
  #7
Old 12-20-2004, 09:01 PM
hj's Avatar
hj hj is online now
Default check valve
Check valves eventually fail, you do not want to have to replace the entire pump when it happens. Install a regular pump and a separate check valve.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
all rights reserved, Love Plumbing & Remodel, 1992-2009
