#1
I've been looking for a couple of 1/2" compression to 1/2" compression shutoff (chrome preferably) valves to feed a hot water recirculator. Brasscraft makes them, but nobody seems to stock them. Part # KTCR34C. Anybody got a source? I've spent over an hour searching on the web and stopped at 3 plumbing supply houses, no luck.
__________________
Jim DeBruycker Important note - I'm not a pro FWIW - Don't try to buy a phone from Nokia on-line |
#2
Are sure you want 1/2" compression. Most of the recirculators have a 1/2" ips size connection and you use a 1/2" ips x 1/2" ips to connect it to the faucet.
#3
The recirculator I have (RedyTemp) uses 1/2" connectors on each of 4 connectors. Two go directly to the shutoffs, and the other two go to the faucets. I have 1/2" to 3/8" hoses to go to the faucets. It came with 1/2" to 1/2" hoses to go to the shutoffs, but I can't find any compatible shutoffs. The supply is PEX. I have the stainless steel ferrule to use a compression fitting on the shutoff, but can only find 1/2"x3/8" valves. It would probably work with using the 3/8" shutoffs readily available, but I was looking to minimize the restriction for maximum efficiency.
__________________
#4
After taking a close look at the supplied hoses, it doesn't seem like it would matter if the shut-off was 3/8 or 1/2", as the diameter of the hose on those that have 1/2" fittings is the same as those with 3/8". So, thanks anyways...guess I should have looked at the internal dimensions of the tubing before trying to figure this out. Just means that I need to buy two more hoses to complete this installation since I can't use those supplied.
__________________
#5
Quote:
| Bookmarks |
| Thread Tools | Search this Thread |
| Display Modes | |
