Terry Love's Plumbing & Remodel DIY forum
Go Back   Terry Love's Plumbing & Remodel DIY forum > Remodel Forum
Reply
Thread Tools Search this Thread Display Modes
  #1
Old 11-22-2004, 04:08 AM
tao_of_howe tao_of_howe is offline
DIY Junior Member
Default Short move of toilet in slab floor
I have a bathroom that is way too small. when you sit on the toilet, your knees are almost on the wall. I want to move the toilet around a foot, and rotate it 90. this will help out the space problem. My question concerns the pipe bellow the slab floor. It is a 1962 house with a concrete slab in the bathroom. What type of waste pipe was commomly used? Will the move affect the venting of the toilet? I know how to handle the concrete, but the drain pipe? What would they normaly use under the slab?
  #2
Old 11-22-2004, 06:40 AM
hj's Avatar
hj hj is online now
Moderator & Master Plumber
Default pipe
It depends on where you are and what plumbers were using then. At that time it could have been cast iron, PVC, or ABS and you will not know which until you open the floor. The type of pipes in the wall could indicate what is under the floor, but sometimes different materials were used in the two locations.
  #3
Old 11-22-2004, 08:04 PM
DIY Junior Member
Default copper?
I have removed the baseboard behind and I can see a large diameter copper pipe directly behind the toilet. The house is a split level, and in the basement, below the kitchen, the drain pipe is copper. The largest pipe I can find is a giant iron pipe that seems to connect to the 2nd story bathroom.
Is this any help?
  #4
Old 11-22-2004, 08:46 PM
jadnashua's Avatar
jadnashua jadnashua is offline
Moderator, but not a Pro
They may have used copper for the vent line; cast iron for the waste. You won't know until you look. You may be able to tell if you remove the toilet and see what connects to the flange. That doesn't mean thatit is the same all of the way, though, as they could have done a transition from one to the other. But, if it is cast iron there, and the stack is cast, that below probably is, too. My unprofessional opinion!
__________________
FWIW - Don't try to buy a phone from Nokia on-line
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
all rights reserved, Love Plumbing & Remodel, 1992-2009
