Basement Bathroom Rough-In
Idoc4u
Indiana
I am intending to cut my 4" thick 2 year old concrete basement floor in order to relocate the roughed in shower drain and toilet flange.
My plan is to cut the concrete with a 7" diamond tipped circular saw blade after spreading some water on the floor to help minimize friction.
Once I cut and remove the concrete and the make necessary plumbing adjustments, my plan is to place vapor barrier over the area and cover with concrete.
My question; is there a certain brand or mix of concrete I should use and how stiff should I mix the concrete that I pour?
Thank you for the replys.
you can just get a high strenth concrete premix from Lowes or Home Depot and you will be fine.
"spreading some water on the floor" is not going to help. You really need a small but continuous flow to the blade.
I used a hose with a spray nozzle with just enough spray to keep down the dust. I had a second person hold the hose. I know its probably not the safest thing since i used an electric saw- but it worked just fine and there was almost no dust.
Use a good Diamond blade
Back
