Control on/off valves on old cast iron radiators
Scuba_Dave
Extreme DIY Homeowner
South of Boston, MA
holidaves.com
I have an oil fired boiler with forced hot water
Cast iron radiators with a dual pipe system & diverter valves on main pipe
Each radiator has an ON/OFF valve on the radiator
Many do not work & are open all the time
Heat works just fine
I'm having two radiators moved, & the on/off valves doe not work
We never turn them off or on
Shining a flashlight down the pipe/valve I can't even see any way that it closes to stop water
Should I have the valves replaced ?
Back
