Terry Love's Plumbing & Remodel DIY forum
Go Back   Terry Love's Plumbing & Remodel DIY forum > Remodel Forum
Reply
Thread Tools Search this Thread Display Modes
  #1
Old 04-14-2005, 05:52 PM
tommysull tommysull is offline
DIY Junior Member
Default installing new vinyl floor
I am in the middle of installing a new vinyl floor in my bathroom. I am having difficulty removing previous porcelain flooring and adhesive. It has been suggested to me to lay lauan plywood over the existing subfloor. I don't have alot of height between the subfloor and the threshold and existing ceramic wall tiles (which I am not removing) Any suggestions on installation would be appreciated. I was thinking of leaving the porcelain tiles under the toilet but chiseling them finely around the edge so as not to have to remove the toilet. Is this an option? Is there a way to lay the new vinyl flooring around the toilet and join it in an inconspicuous spot behind the toilet? Thanks in advance for any advice.
  #2
Old 04-14-2005, 09:37 PM
jimbo's Avatar
jimbo jimbo is online now
Moderator and Plumber
There is no way to remove ceramic tile and end up with a surface smooth enough for vinyl. At best, you have to bring in a grinder and create an awful mess. Still probably end up putting some 1/4" subfloor. You could put some 1/8 luan directly over the existing ceramic. I would remove the toilet and build up the flange, but it is definitely possible to cut the vinyl behind the bowl and make a good install that way.
  #3
Old 04-15-2005, 01:09 PM
Gary Swart's Avatar
Gary Swart Gary Swart is online now
When I put down some expensive vinyl in my kitchen several years ago, I was advised to use an underlayment called, "Multi-Ply. This is 1/4" x 4' x 4' plywood that has no voids in the inner layers that won't break through if stepped on by high heels. At Lowe's it costs about $10 a 4x4 sheet which is only a couple of bucks more than fir plywood. Multi-ply may be a brand name so there may well be similar products under a different name. I'd scrape, chisel, grind, and sand the old adhesive to be as smooth as possible. If I remember correctly, the multi-ply was screwed to the floor joists, and the resulting holes were filled with a special putty that wouldn't shrink or crumple. A flooring center could give you product names.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
all rights reserved, Love Plumbing & Remodel, 1992-2009
