ShowerGuard from Guardian?
natalia
Philadelphia PA
We are in the process of remodeling master bathroom and our contractor submitted a quote for a new frameless shower 3'x4' (glass and installation) for $6,000. He didn't break anything down, but a significant part of it he says is ShowerGuard sealing. Needless to say, this is twice as much as our budget and I am trying to see if anyone had ShowerGuard applied in their glass shower.
Thank you,
Natalia
ShowerGard must be a trademark as it's not a generic term. There are some treatments that can be applied to glass at the factory that chemically change the outer surface. Basically, they bond a layer of material to it so that the microscopic irregularities of the glass are smoothed out. SOrt of like waxing your car, but applied so it becomes part of the glass and doesn't wear out like wax would. It makes it easier to keep the glass clean as the water beads up and flows off, so mineral deposits and soap scum find it hard to stick. A couple I've seen cost around $7-10 per square foot, so that does add up if you've got a lot of glass surface in the doors/walls. Now, is it worth it? Depends. A properly built shower for $6K isn't out of line, but it depends on the area you live in and the materials chosen.
Check out www.johnbridge.com for an education on building a shower...it's a similar forum that specializes in tiling, where showers are a major component.
Hi Jim,
Have your thoughts on shower coatings changed? Seems like you are saying that the chemically bonded appear to be the best. Do you still think a coating of some kind is generally needed? We will try our best to squeegee the shower glass but over time I'm sure we may get a bit more lazy / miss more days than at the start. Seems like you need to squeegee anyways so is it really gonna make a difference?
thanks,
ShowerGuard is a "precoated glass" which claims to be stain resistant. Whether it is worth the added cost is something you will have to decide for yourself, Check their website to check it out.
Old thread but I'm wondering what anyone's personal experience is with Showerguard. getting a quote Monday for my 42 inch square shower with 2 walls of glass
Back
