Testy whirlpool bath switch
Jumpyg
Michigan
Hi, I've got a Kohler whirlpool bath model K-1157-CN that is about nine years old. I just moved into the house three months ago. This bath has a GFCI receptacle protecting it, and it starts via an air-actuated switch. Since we moved in, the switch has been "sticky" and doesn't work most of the time. I'll press the switch in, nothing happens, then it takes 20-30 seconds for the switch to go back to its normal position. Then I try it again. After several attempts, it will start up. Same drill shutting it off.
Can anybody suggest a way to fix this? Maybe take apart the switch and lubricate it? Replace the switch?
Thanks much for any advice.
Toto Drake
Back
