Terry Love's Plumbing & Remodel DIY forum
Go Back   Terry Love's Plumbing & Remodel DIY forum > Remodel Forum
Reply
Thread Tools Search this Thread Display Modes
  #1
Old 03-26-2005, 01:55 PM
SteveW's Avatar
SteveW SteveW is offline
DIY Senior Member
Default Need air inlet in laundry room?
Here's a question for the group: Is it necessary to have some sort of air inlet for a laundry room, to let air in for an electric dryer?
I have a small laundry room on the main floor of my house. I notice that when the dryer is running, and I leave the door ajar, the door is pulled into the room by the air being drawn into the dryer. It dawned on me that a clothes dryer is basically a big air pump...
Is it OK to close the door? There is a 1-inch gap under the door, but does this compromise the efficiency of the dryer? My wife doesn't like to leave the door open, due to our dog getting into the room (and the noise).
If we need more air flow, any creative thoughts, other than putting a grill on the door? Don't want to do that since it's right in our main hallway. Could I open up a small air vent into the ajoining closet?
Or not worry about this?
  #2
Old 03-26-2005, 02:41 PM
Terry's Avatar
Terry Terry is online now
Forum Admin, Expert Plumber
You will get more pulling power from the dryer is the room is vented.
You can check to see how much it would help, by having someone open the door while holding your hand outside over the dryer exit.
If there is a difference, you may want to cut through the drywall on put two grills in.
Most laundry rooms have a heat duct that adds some "return air".
  #3
Old 03-26-2005, 03:36 PM
SteveW's Avatar
DIY Senior Member
My little laundry room is so small it doesn't have a HVAC duct of any type.
I like the idea of checking air output with the door open and closed -- tried it and no obvious change in airflow at the outside exit. I think I'll go ahead and add a couple grills in the drywall anyway. I guess there's no reason why the two grills actually need to have a "duct" between them, is there? The stud cavity (interior wall) would be closed anyway, so I should be able to just cut drywall on both sides, screw in a grill on each side, and be done, right?
  #4
Old 03-26-2005, 10:58 PM
jadnashua's Avatar
jadnashua jadnashua is online now
Moderator, but not a Pro
I think you'll find that clothes dry faster if you don't have a restriction in the air for the dryer. WIth the cost of electricity going nowhere but up, it makes sense to make it's work easier. In a REALLY tight house, exhausting a lot of air without some coming in from outside also creates problems. When the dryer is running, the air you are blowing outside has to be made up from somewhere or you'll be sucking things like exhaust fumes from the heater into the house, or cold air through the cracks in the house. Same problem with a hood vent on the stove (assuming it doesn't just recirculate the stuff after trying to filter out the grease, etc.). They make air-to-air heat exchangers for this problem - preheats or cools the air based on the season by exchanging energy in the air stream, minimizing the energy loss and providing good fresh air to the building. I read somewhere that they are required in new construction in Canada, and probably a good idea here as well. My unprofessional opinion.
__________________
FWIW - Don't try to buy a phone from Nokia on-line
  #5
Old 03-27-2005, 06:33 AM
SteveW's Avatar
DIY Senior Member
Good points, Jim. My house isn't particularly tight, but I could really see how a clothes dryer or high-efficiency fan in a range hood could cause some real problems in a tight house. I've heard before that you need air for combustion of water heaters, furnace, etc., but never thought about the effects of the various exhaust fans we have (the clothes dryer being one of them...)
Thanks for the feedback!
  #6
Old 03-31-2005, 10:44 PM
resq944 resq944 is offline
DIY Junior Member
Most Dryer manufacturers will mandate a certain amount of ventilation in a closed laundry room or closet. For instance my HE3 Dryer required either 24 sq" of ventilation area or a louvered door.
  #7
Old 04-01-2005, 05:11 AM
SteveW's Avatar
DIY Senior Member
Another good point. I didn't think to check out the owner's manual...
  #8
Old 04-02-2005, 09:09 PM
copperhead copperhead is offline
DIY Junior Member
Send a message via Yahoo to copperhead
The louvered door would probably be your best option but if you go with the two grills you can add some blocking to the top and bottom of your cavity by cutting some two bys the length you need and inserting them between the sheet rock. Screw through the sheet rock on both sides to hold it in place and then run some angled screws into the existing studs. Torx screws work well, somewhat cashy but your fingers and patience will appraeciate them.
  #9
Old 04-02-2005, 09:13 PM
DIY Junior Member
I forgot to mention that this may help if by chance your grills develop the squeaks and rattles that gives you the sense of a trailer park!
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
all rights reserved, Love Plumbing & Remodel, 1992-2009
