Terry Love's Plumbing & Remodel DIY forum
Go Back   Terry Love's Plumbing & Remodel DIY forum > Shower & bathtub Forum
Reply
Thread Tools Search this Thread Display Modes
  #1
Old 09-06-2007, 05:36 AM
Bob in NH Bob in NH is offline
DIY Junior Member
Default leak in Delta 13 series shower
I have a leak in a Delta 13 series single knob shower control. I have replaced the little rubber seats and springs, however when it was put back together, the mixer housing (white plastic part) was put in backwards, and the person who did it cut off the little triangle tabs to line up with the slots in the pipe. I took it apart again to put the white plastic back on correctly and now it leaks worse.
I think what might have happened is the cartridge that goes behind the mixer valve and into the water pipes, I think this may have moved. The drip leak is now almost a steady trickle, and its hot water.
My suspicion is the cartidge between the mixer valve and the pipe is not seated all the way into the pipes and/or the o-rings on the back end of this need replacing. When we originally took it apart to get to the seats I didn't realize this part could come out as well.
Does this make sense? If so, how do you get that cartridge out of the pipe? I am not a big fan of using force to get things apart when I am not sure how they are suppose to come apart. Looks like i might just need to grab it and pull, but not sure and don't want to break anything.
Thanks for any advice you have!
--Bob
  #2
Old 09-06-2007, 04:32 PM
BAPlumber's Avatar
BAPlumber BAPlumber is offline
If i'm reading this correctly, the plastic cartridge should just pull out.
http://www.deltafaucet.com/media/Pro...13422_c6d1.pdf
__________________
Brent
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
all rights reserved, Love Plumbing & Remodel, 1992-2009
