Terry Love's Plumbing & Remodel DIY forum
Go Back   Terry Love's Plumbing & Remodel DIY forum > Shower & bathtub Forum
Reply
Thread Tools Search this Thread Display Modes
  #1
Old 09-05-2007, 08:02 PM
Placid Placid is offline
DIY Junior Member
Default Bathtub Faucet Issue
I had a faucet installed in my remodeled bathroom by a plumber...however, I now have an issue. The hot water is only coming out of the faucet.
I took the face plate off and closed the hot check valve and completely opened the cold. Nothing, no cold water. I loosened the cylinder a little and sure enough water came out, which I quickly re-tightened.
The cold water line to the faucet is also attached to the kitchen faucet, where I am getting cold water.
Any thoughts?
I would go back to the plumber expect, he burned a hole in my tub since he didn't use a drop cloth....and we agreed he wouldn't get paid.
  #2
Old 09-05-2007, 08:24 PM
jimbo's Avatar
jimbo jimbo is online now
Moderator and Plumber
Picture of the faucet would help so we know what we are dealing with.
  #3
Old 09-05-2007, 08:35 PM
DIY Junior Member
  #4
Old 09-05-2007, 09:44 PM
cwhyu2's Avatar
cwhyu2 cwhyu2 is offline
DIY Senior Member
That a delta ? Check the stops .The sloted things .They are senitive.
Adjust as they look like one is not open all the way.
  #5
Old 09-06-2007, 05:58 AM
DIY Junior Member
I have opened and closed both stops multiple times.
The hot water stop works.
  #6
Old 09-06-2007, 08:33 AM
cwhyu2's Avatar
DIY Senior Member
It maybe something is causing the balancing piston to not operate properly.
That would be between the cold stop and valve to take this out to
inspect unscrew and re move piston it sould rattel if not it is stuck
will add more latter.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
all rights reserved, Love Plumbing & Remodel, 1992-2009
