Terry Love's Plumbing & Remodel DIY forum
Go Back   Terry Love's Plumbing & Remodel DIY forum > Shower & bathtub Forum
Reply
Thread Tools Search this Thread Display Modes
  #1
Old 09-04-2007, 04:41 PM
bobv bobv is offline
DIY Junior Member
Default Shower/tub plumbing
I am installing a jetted tub in a three wall alcove with a shower surround. I would like to deck mount a spout in the front corner of the tub deck instead of on the wall and use a single handle wall mounted control valve to control the tub fill and shower.
I was reading somewhere about limiting the distance from the valve to the spout to 18" prevent what I think they called "water rise" causing water to come out the shower head when filling the tub. I have seen a Kohler valve that has the diverter mounted at the valve, but it has instructions not to use multiple elbows, or PEX between the valve and the spout.
Does anyone have suggestions or should I re-think my plan?
Bob
  #2
Old 09-04-2007, 08:56 PM
Furd's Avatar
Furd Furd is offline
DIY Senior Member
I would think that if you increased the size of the pipe immediately after leaving the valve assembly that you could alleviate this problem.
Most valves have 1/2 inch outlets so I would go immediately to a 3/4 inch pipe all the way to the remote spout. I don't know if "they" make a spout that uses a 3/4 inch connection but if you could find one it would be preferable to reducing back to 1/2 inch at the spout.
HOWEVER, I am not a plumber and I have never tried this...but I might.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
all rights reserved, Love Plumbing & Remodel, 1992-2009
