#1
Hello,
Well here I am with another question. What type drill bit do I use to cut a 3 1/2 inch hole in a fiberglass enclosure and what special precautions to use to keep from chipping the gel-coat? Thanks in advance. Katman104 |
#2
A normal lenox hole saw. The more teeth the hole saw has the better. A fast turning drill is a must.
I use a milwaukee hole-hawg for all my drilling...setting it on low to drill tubs. Keep it straight so it doesn't bind!
__________________
See? I knew sooner or later you'd be looking at my... signature.
#3
A hole saw is the way.Do not use a jig saw.Youcan get one at your local
hardwere store or rent one, |
#4
Quote:
The shower wall is not that thick so if you force it or try to go too fast the hole saw can start to bounce around and possibly damage the shower. BTW,a metal cutting hole saw is what Rugged was describing with "many small teeth" as opposed to a wood hole saw with "less big teeth." As always, use gloves,eye protection,etc... Last edited by Old Dog; 08-25-2007 at 03:01 AM. Reason: repeated words |
#5
Thanks to all that answered I appreciate the information and will try to pick one up today at Lowe's if they have one. At one Lowe's store they tried to sell me one that I did not think had enough teeth to it so I did not buy that one. Decided to wait and post on this forum for information. Glad that I did.
Again thanks to all that responded. Katman104
#6
If you're installing a Delta monitor series....I always used a 4-3/4" hole saw, the same one I "used" to drill for my closet flanges.
Ahhhh the memories. Bad thing is I got to drill for one this coming week.
__________________
#7
If you use the right sized cutter the chrome trim plate will cover any chips. I have used either a hole saw or a fine toothed narrow SawZall blade to cut the holes.
#8
Quote:
#9
Thanks to all that answered, I bought the 3-1/2" hole saw and will attempt this coming week.
katman104
| Bookmarks |
| Thread Tools | Search this Thread |
| Display Modes | |
