Terry Love's Plumbing & Remodel DIY forum
Go Back   Terry Love's Plumbing & Remodel DIY forum > Shower & bathtub Forum
Reply
Thread Tools Search this Thread Display Modes
  #1
Old 08-23-2007, 07:56 PM
katman104 katman104 is offline
DIY Junior Member
Default Type of supply pipe to shower valve.
Hello,
Is it ok to use CPVC 1/2 inch pipe to input of shower valve and then use copper to shower head and Tub spout?
katman104
  #2
Old 08-23-2007, 08:16 PM
Lancaster's Avatar
Lancaster Lancaster is offline
DIY Senior Member
Thats the way it is most often done around here.However,dont use plastic adapters to screw into the valve inlets,use the ones that are CPVC slip by brass IPS.And be sure to use a "drop ear" elbow at the shower arm so that it can be secured with fasteners.
Copper is rarely used for water lines around here because the water is agressive,however for the shower riser and tub spout elbow copper is preferred for its extra rigidity.
  #3
Old 08-24-2007, 03:56 AM
DIY Junior Member
Lancaster,
Thanks for the information.
Katman104
  #4
Old 08-24-2007, 04:08 AM
DIY Junior Member
Lancaster,
Is there a web site that explains what depth to mount shower valves behind the enclosures for proper fit when you put the enclosure in place. I have tried to get Moen to contact me by phone and email but, they have not done so.
Or is this different for every install depending on the enclosure itself? Sure would appreciate any help on this from anyone since the bathroom remodel is to this point. Thanks in advance
Katman104
  #5
Old 08-24-2007, 04:38 AM
Lancaster's Avatar
DIY Senior Member
Yes there is.
http://www.moen.com/shared/pdf/instr...ets/MT692C.pdf
  #6
Old 08-24-2007, 07:04 AM
jadnashua's Avatar
jadnashua jadnashua is offline
Moderator, but not a Pro
The valves typically come with a plaster guard - a cover to keep things clean and help align the valve prior to installation of the finished wall coverings. Typically, there will be min/max lines on that cover for the depth. The guide also is the template of how big, where, and the shape of the hole that is needed in the wall. This is also usually discussed in the installation manual, which you can often find on their website. this varies and is specific for each company and each valve, so no generalizations are valid for an actual specific installation.
__________________
FWIW - Don't try to buy a phone from Nokia on-line
  #7
Old 08-24-2007, 07:28 AM
DIY Junior Member
Exclamation
Quote:
jadnashua,
The AquaGlass one piece tub and shower unit is 326032A-R unit and the faucet is a Moen 82496BN.
It has a plaster guard that has "thin wall" and a place that says "Thick wall" on it. I am not sure of the distance between the stud wall and the finished side of the enclosure so I do not know what depth to mount the valve between the studs
Thank's for any help you can provide.
katman104
  #8
Old 08-24-2007, 08:50 AM
jadnashua's Avatar
You may need to study the shower enclosure drawings. As long as the valve sticks out and the enclosure sits between the thin and thick wall lines, the trim should fit.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
all rights reserved, Love Plumbing & Remodel, 1992-2009
