#1
Hello anyone,
First timer here with a couple of questions. i am currently working on a bathroom remodel. i have taken out the tub and all walls and i am on a concrete slab. i am installing hardibacker on the new shower area. i had a composite shower pan poured. the pan was poured into a thin fiberglass form that has sides about 2" high. the pan was installed and i put the hardibacker down to the shower pan (1/2" from the pan). I now have several questions. 1. how should i build the curb? mud or with hardibacker will the mud be ok on the compsite pan? 2. should i have put one of the plastic/rubber liners in before the composite pan was installed ( the shower pan dude said no) 3. how far down should i put the screws in to the hardibacker *i did install a plastic liner between the studs and the hardibacker. thanks for your time! -dirt diggler |
#2
Sounds like a recipe for disaster. Did this come with a special drain? It may work, but in the long term, I don't think you'll be satisfied.
Suggest you try asking this at www.johnbridge.com. This is not one I've dealt with. It appears that you have studs that you attached the cbu to. That needs a vapor barrier behind it, then the barrier should run down into the shower pan. By code, the waterproof pan must run up 3" above the curb. If your pan is only 2", and it is full of cement, it doesn't meet code.
__________________
Jim DeBruycker Important note - I'm not a pro FWIW - Don't try to buy a phone from Nokia on-line |
#3
Hey Jim thanks for the reply. i don't think i was clear. The shower "pan" is a cultured marble shower base. This base sits in the fiberglass tray. My CBU does come down over this fiberglass tray to the cultured marble base. However this base has no curb. Should i build a curb with wire lathe and mud or with more of the cement board? i just don't know if the mud curb will adhere to the cultured marble shower base.
thanks. |
#4
Not sure about the best way to solve this...you'll get more traffic on this sort of thing at www.johnbridge.com; Terry won't mind! Anybody?
__________________
#5
will send to the john bridge forum. thanks for the advice!
| Bookmarks |
| Thread Tools | Search this Thread |
| Display Modes | |
