Terry Love's Plumbing & Remodel DIY forum
Go Back   Terry Love's Plumbing & Remodel DIY forum > Shower & bathtub Forum
Reply
Thread Tools Search this Thread Display Modes
  #1
Old 08-16-2007, 09:28 AM
kahcrt kahcrt is offline
DIY Junior Member
Default Lifespan for Cast Iron Tub?
A question for you knowledgeable, helpful folks: how long can I expect a cast iron tub to last?
Is it reasonable to expect it to continue in service beyond 50 years?
We are upgrading the bathroom in an 1850s home, and want to put in a Swanstone tub surround. I am guessing the tub dates to the early 1960s. It seems to be in pretty good shape, and we like the size and feel of cast iron.
But... I don't want to be faced with replacing it, say, 5 years from now after a major upgrade this year. And I'm concerned that a new tub couldn't be put into place later and not ruin the new-ish tub surround.
Thanks for any advice you may have.
  #2
Old 08-16-2007, 10:47 AM
jadnashua's Avatar
jadnashua jadnashua is offline
Moderator, but not a Pro
It is doubtful you could replace the tub without ruining the surround. As long as the finish isn't compromised on a cast iron tub, it should last a very long time...decades. To keep the finish intact, you don't want to use abrasive cleaners, not drop hard objects that will chip it, and try to keep sand, etc. out of it that could wear away the surface gloss. Even if it is no longer glossy, as long as the iron base is not exposed, it shouldn't rust.
__________________
FWIW - Don't try to buy a phone from Nokia on-line
  #3
Old 08-16-2007, 11:38 AM
DIY Junior Member
Question
Thank you! It is comfy, but certainly not glossy.
Just went over it inside and out (what I can reach) looking for any indication of rust. Getting into the tub and looking up underneath the overflow fixture -- I do see a few specks of rust there.
Maybe that should that be taken as an indication of worse to come...?
Our alternative plan was to take out the cast iron tub and install a Kohler / Sterling interlocking tub & surround... until I saw this morning's post about the Sterling Damaged by Bodysoap. Yikes!
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
all rights reserved, Love Plumbing & Remodel, 1992-2009
