#1
I installed a Pegasus shower head and faucet. The selector is a single handle which does both hot and cold water.
For some reason when I turn the water on (faucet) water travels upwards to the shower head. This only happens if the water is turned on halfway. When it's fully turned on, the shower head does not drip. When I look at the cartridge, I can see a clear path from the lower faucet to the upper shower meaning there is no sort of valve in between the two. Is this normal? If I turn on the tub faucet to a medium temperature, the shower head will always drip? |
#2
It's normal on many valves to not include a divertor valve. This requires you to use the right sized pipe to connect things. If the tub spout is restricted at all, the backpressure will allow water to feed up to the showerhead. Do you know what kind and size of pipe connects the valve to spout and to the showerhead?
__________________
Jim DeBruycker Important note - I'm not a pro FWIW - Don't try to buy a phone from Nokia on-line |
#3
I'm sorry to say this, but I won't install Pegasus..I've had trouble when a customer picked it up and I installed it..I just think the internal machining is sloppy.
The only possible thing you might be able to do is what Jim just said...see if you have any restriction in flow to the spout.
__________________
"The biggest regrets we have in life are the chances we never took." |
#4
Quote:
I believe it is 1/2 NPT coming out of the unit going to a 1/2 sweat fitting. Then it turns with a 90 degree elbow and comes out of the faucet. |
#5
Quote:
The only one I put in, the balancing cartridge ceased after 2 weeks...was working fine, then no hot water when I returned for the finish. I've done countless Kohlers, Grohe's, Symmons, Moens...a few Delta's...never saw anything cease like that brand new.
__________________
#6
Quote:
damnit. |
#7
Quote:
__________________
#8
go to one that is still open.
#9
I'm a very similar problem in my main floor bath. I thought it was a problem with some mineral build-up in the "generic" tub spout/diverter replacement I picked up several months ago, so I bought an Alson's (1010L). I threaded the new spout on, and it actually made the problem worse! What was a trickle of water out coming out of the shower head, I now have significantly more water flowing without any [intentional] diversion. It's also a half-inch copper feed to the spout... Any thoughts?
| Bookmarks |
| Thread Tools | Search this Thread |
| Display Modes | |
