#1
Installing a NEW Moen TL181 ... new valve installed. New shower installed. Turned hot water on (from shut off) - handle is off position - no water (perfect) Turned cold water on (from shut off) - handle is in off position - cold water comes out, not just dripping ... medium pressure so quite a bit of water. Any ideas ? We've turned the stem to every position possible and it will not shut off. Please help.
Thanks |
#2
OK something may have got caught in cartrage this can cause this
problem.Rotating a positemp stem will not solve the problem.Try and look at install instructions.This may give some insight to what is causing this condition. |
#3
Well it's all brand new so unless it came with something 'extra' in it I wouldn't know. I guess a defective cartrige could be the problem?
#4
New installation, could be debris in the cold cartdrige preventing the cartridge from closing.
I had a few come back with wood chips, people cut the copper lines and do not cap off and renovate and all the debris goes in the lines and they turn on for the first time and where does it go but inside the cartridge. |
#5
I hear what your're saying peanut. Everything was capped off (it's a single lever model) - I spoke to Moen this morning and if the 'so called plumber' we had that installed the valve didn't remove the cartridge before soldering that also could cause it. Moen is sending a kit to me and I'm praying that solves the problem.
| Bookmarks |
| Thread Tools | Search this Thread |
| Display Modes | |
