Terry Love's Plumbing & Remodel DIY forum
Go Back   Terry Love's Plumbing & Remodel DIY forum > Shower & bathtub Forum
Reply
Thread Tools Search this Thread Display Modes
  #1
Old 08-12-2007, 12:24 PM
clmccain87 clmccain87 is offline
DIY Junior Member
Default Can someone identify the model of this delta faucet
I was told it was a delta 1700 series but bought a new trim kit and guess what it doesn't fit. Since it was special order I'm out the cash so now I want to see if someone can tell me for sure what it is. Thanks.
  #2
Old 08-12-2007, 01:11 PM
GrumpyPlumber's Avatar
GrumpyPlumber GrumpyPlumber is offline
Licensed Grump
It's a 1300 series, I believe.
__________________
  #3
Old 08-12-2007, 01:44 PM
Peanut9199's Avatar
Peanut9199 Peanut9199 is offline
It is a 1700 series but it's the old style Delta changed the style March 27/2006 , but i don't have a breakdown on the old style and for some reason thier web site only shows the parts for the new style.
1300/1400 does not have the volume control.
I will look on Monday when i can get at my catalogues, unless someone else has them.
  #4
Old 08-12-2007, 04:24 PM
DIY Junior Member
Thank you. I'll hold out hope that I won't have a brand new bathroom with a 20 year old shower faucet as you see it's a 104 year old house and no access panel our options right now are tear out the brand new tile, tear out the dining room cabinets, or live with the old faucet.
  #5
Old 08-12-2007, 04:50 PM
jimbo's Avatar
jimbo jimbo is online now
Moderator and Plumber
It is a Monitor 1700 series. Parts and cartridges are readily available, just not at HD . Turn off the water, take all the parts, including the internal parts, with you to a big plumbing supply house.
Removing the cartrige retaining nut you have to be careful. If it is stuck and you just put a big wrench on it, you will cause FATAL DAMAGE to the valve body. Start soaking right now with white vinegar. Then after a day, start applying PB blaster and give that a day to work. Tap at it, even use a propane torch to heat it some. If these techniques do not work, come back for more advice. Just be careful not to twist that nut too hard!
  #6
Old 08-13-2007, 04:05 PM
DIY Junior Member
Thanks to everyone that helped, went to a plumbing parts store today and got an old style cartridge that will fit the new 1700 series trim kits. Finally it all fit together.
  #7
Old 08-18-2007, 09:31 PM
Dan Pick Dan Pick is offline
DIY Member
Default Correction
Glad to hear everything worked out. Actually its a 1500 Series Pressure Balance valve........the predecessor of the current 1700 Series
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
all rights reserved, Love Plumbing & Remodel, 1992-2009
