Long, Deep, Narrow Whirlpool
juju
Hi,
I am new to the Forum and I have found plenty of good information here.
I have a quite narrow but long bathroom.
Basically, I am looking for a maximum width of 32 inches, and the longest (up to 6 feet) and deepest (up to 30 inches) I can find.
I would like to have both air bubbles and jets.
The best I have found is the Apollon Neptune bathtub:
http://www.neptuneb.com/english/bains/index.html
It is 29 1/2 x 65 1/4 x 20 1/2 , which fits my dimensions, although I could use a bit longer & deeper.
Please let me know if you have another recommendation.
Thanks for your help.
Juju
I put in a Jason air tub last fall - I like it so far. This is a relative of the Jacuzzi family (a son?). They have a fairly extensive line, but don't know if they have one that meets your requirements. They do make some models up to 6' and beyond (I've got a 6' one). www.jasoninternational.com
millions of tubs...
been there, done that.
There are 3 sizes: 60",65-66",72".
You want the latter...
there are a lot of companies out there...
Neptune
Kohler
American Standard
Watertech
Aquatic
Jason
Each has slightly different widths and depths....thousands of models to choose from !! Good luck !!
Just make sure you can fit it into your space with access to the pump motor and inline heater.
Hi,
yes, thanks for your advice.
The only challenge is that the vast majority of the tubs from those companies are wider than 32 when longer than 60, or deeper than 20!
So, since i have only 32 max in width, the longest I have found so far is actually 66, and 20 deep, from Neptune.
For instance, I have not been able to find anywher a 32x72, deep whirlpool...
I will check some of the brands you mention and I have not checked yet.
Who is up for the challenge for a 32x72? I offer a free soak!
Juju
Back
