Terry Love's Plumbing & Remodel DIY forum
Go Back   Terry Love's Plumbing & Remodel DIY forum > Shower & bathtub Forum
Reply
Thread Tools Search this Thread Display Modes
  #1
Old 08-06-2007, 06:58 PM
sixfoot sixfoot is offline
DIY Junior Member
Question Old Brass Drain
So I just demolished my shower that was built 50 years ago. It is in a basement on a concrete slab. The drain is made from brass. When I shine my light down the drain it is about 2 feet to the trap. I managed to get the brass drains' interior to come up about 6 inches. The drain does not come out. It is a slip fitting with a flange that stops at the lip. Anyway, I am planning to "pour" a shower pan with that thick black plastic sheeting. It looks as though I need to use this drain somehow so that I can tile the floor as well...Any Ideas???????Thanks.
  #2
Old 08-06-2007, 07:01 PM
DIY Junior Member
The whole drain and trap assembly is completely entombed in the concrete. There is no working room. The Drain itself is in good shape, however, and just want to be able to create a watertight floor with tile and the old drain. The drain does not appear to have any type of weeping....
  #3
Old 08-06-2007, 08:19 PM
jadnashua's Avatar
jadnashua jadnashua is offline
Moderator, but not a Pro
To do a proper shower, you need a clamping drain with weep holes.
If you're going to build a tiled shower, I suggest you check out www.johnbridge.com they are almost exclusively devoted to showers and other tiling projects.
__________________
FWIW - Don't try to buy a phone from Nokia on-line
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
all rights reserved, Love Plumbing & Remodel, 1992-2009
