Terry Love's Plumbing & Remodel DIY forum
Go Back   Terry Love's Plumbing & Remodel DIY forum > Remodel Forum
Reply
Thread Tools Search this Thread Display Modes
  #1
Old 09-22-2004, 09:19 PM
dklein2149 dklein2149 is offline
DIY Junior Member
Default Laundry room remodle
I am remodeling our laundry room. I plan to replace the existing concrete 2 bowl laundry tub with a new fiberglass two bowl tub. I have several general plumbing questions: I want to install a "valve box" for the washer connections. I am also planning to run the supply plumbing for the laundry tub behind the wall. Can I use the same air chamber for both sets of valves or do I need an air chamber for each set? Currently one set of air chambers exists (one for hot and one for cold) but both the faucet and washer connections are connected vertically in series. With the new plan the valve box will be 12" offset from the planned new laundry faucet supply lines. Also is it ok to replace the old galvanized waste line with a plastic pvc line into the main drain?
  #2
Old 09-23-2004, 06:43 AM
hj's Avatar
hj hj is online now
Moderator & Master Plumber
Default remodel
AIr chambers, when they work, are best installed at each fixture. But since they are seldom used anymore, and have a limited lifetime of actual service, anything you do will work until they fill with water and lose their functionality.
  #3
Old 09-23-2004, 07:53 AM
jimbo's Avatar
jimbo jimbo is online now
Moderator and Plumber
As hj mentioned, air chambers were a "good idea at the time" but have prooved to be effective for only a short period of time, and then become a place for water to stagnate and cause problems. You should get actual hammer arrestors ( the kind with rubber bladders) and install one set, or a set at each fixture. Sioux Chief makes them and others as well.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
all rights reserved, Love Plumbing & Remodel, 1992-2009
