ecu pirate
- Messages
- 9
- Reaction score
- 0
- Points
- 0
On another note, I can only fill that tub less than halfway before I run out of hot water. Any ideas on that? That is the reason it doesn't get used.
I like the setup too, but that shower is not big enough for Mr AND Mrs ECU Pirate. It is quite tiny. You are right about the window limiting my options. I could only extend the shower area about 4-5 inches.Pewterpower said:The first thing I see is that big window. Unless your willing to board it up, then it's gonna limit your options.
I kinda like what you got. It's very clean and quite new looking. Maybe just yank the tub and give Mrs. Ecu Pirate (I know, I'm making assumptions....) a huge vanity and make-up center.
Just my two cents.![]()
whats a trap?jadnashua said:Sounds like it may not have its own trap?
If done right, a glass block window in a shower can be made watertight.
so what can i do to get rid of the damn gnats?jadnashua said:Look under your sink...that U-shaped fixture is a p-trap. There needs to be one for each fixture in the house except for toilets, which have it built-into them. they may have tied the shower drain to the tub's trap, leaving a 2-3' or longer arm, eventually this gets lined with hair, soap, body oils, etc., and gnats just love that. There should be a trap right under the shower.
search here for tempering valve, to see how to set your HW heater's temperature higher and then have that ultrahot water get combined immediately with a little bit of cold water to bring the hot water temperature down to a more acceptable less scalding temperature. This gives you more volume of hot water. You can then fill the tub.ecu pirate said:... can only fill that tub less than halfway before I run out of hot water. ...
