problem with aquastat setting for coil
Bbillcee
New York
if i understand correctly the aquastat used on a boiler with a coil keeps the boiler water at a certain temp so when u need hot water it does not have to wait to get hot water
lately hot water seeems to take a while to come....i had the aqustat at 160 and raised to 170
it has been very cold here lately....
would going higher on the aquastat be ok?
or i'm wondering if its a problem with the aquastat itself
last year i remeber the hot water meter o the hot water pipe would stay round 120 ....now it stays around 80-90 average
the boiler and coil is 1 year old
A boiler coil for domestic hot water needs the boiler to be fairly hot to work well, especially in the winter when the incoming cold water can approach freezing. Often, the thing is designed for 180-200 degrees. Yes, you can adjust it up, but it will increase fuel use, but you'll have hotter water.
Back
