Terry Love's Plumbing & Remodel DIY forum
Go Back   Terry Love's Plumbing & Remodel DIY forum > Remodel Forum
Reply
Thread Tools Search this Thread Display Modes
  #1
Old 01-31-2005, 03:34 PM
Aunt Snow Aunt Snow is offline
DIY Junior Member
Default Remodel has drain problems
I recently had a basement room remodeled, and I now have a drain problem.
The house is on a hillside, so the basement consists of 2 adjoining rooms on two different levels, the slab of the upper room is about 3 feet higher than the slab of the lower room.
All the plumbing in the basement drains to a septic tank.
Before the remodel, the lower room had a toilet, a laundry sink, and a standpipe drain for a washing machine, and a hot water heater. The upper room had a sink.
As remodeled, the water heater has been moved to the upper room, directly on the other side of the wall from its previous location. The washing machine has been moved to the upper room and uses the supply and drain from the sink formerly located there.
In the lower room, the toilet remains in its original place. A new shower is located where the washing machine standpipe had been. A new lavatory was installed in the location where the water heater once stood. The supply and drain for the laundry sink were capped off.
Everything seems to work fine --- except for one thing. Whenever the washing machine drains, I get a "glub glub glub" sound from all three fixtures in the lower room. An air bubble comes up in the toilet. And about a gallon of water from the washer backs up in the shower. It drains fine after that.
All the fixtures except the new lavatory are hooked up exactly where old fixtures were. (Of course, the shower drain is open at floor level instead of 3' above, when it was the laundry drain.)
What's going on?
I have very little confidence in my contractor to fix this, but I want to diagnose the problem and hire another plumber. I also want to know where the contractor went wrong.
  #2
Old 01-31-2005, 05:22 PM
Mike Swearingen's Avatar
Mike Swearingen Mike Swearingen is offline
DIY Senior Member
Sinks should have 1.5" drains, showers and washing machine standpipes 2" drains, and toilets 3" or 4" drains...all vented after the traps.
The washer may be draining into a line that's too small to handle the higher discharge load of modern washers, if it's hooked up to a 1.5" sink drain.
Mike
  #3
Old 01-22-2007, 10:09 AM
kathywhite
Guest
Posts: n/a
Mike
I agree well, I am in the middle bathroom remodeling too but I am having bad time finding website that are related to this topic
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
all rights reserved, Love Plumbing & Remodel, 1992-2009
