My sewer cleanout is in a short crawlspace with less than 6 in. clearance to a furnace plenum so it's really not usable. The bell end with the brass cleanout (which is frozen into place) is on the end of the 'Y' from the toilet so there seems to be insufficient space to try to extend from the inside to make it more accessible.
When this line was rooted out about 20+ yrs ago and there were some roots in the line. I am not having problems at this time but the street is being reworked and if I need to replace the line it will be much, much cheaper to get a permit to do it before the street work is finished. I need a cleanout merely to scope the line to see if there is a problem developing. It's been recommended by a roto-rooter vendor to install a sewer line cleanout outside my house.
It all makes sense to me except....
Once I cut the line I see a high likelihood that roots can work their way between the rubber adapter hub and the pipe. I've dug and exposed the pipe and now just have to get up the nerve to actually cut it.
I envision roots worming their way under this rubber connection and into the line. The local D-I-Y store recommend "Plumber's Goop" placed on the rubber adapter (between ABS 'Y' and iron pipe) to help keep roots out. Will this work or is there something else to consider?
The rubber adapter comes with the usual screw clamp and I can imagine them rotting out in a couple of years. Is there something else I can buy to improve the longevity of this connection?
Finally, is there any usefulness in installing a 2nd cleanout to go upstream? The distance upstream would be about 8ft before it bumps into the end of the line & brass cleanout that is inaccessable. In between are 2 lines that come in from the top so I doubt anyone would be so lucky to have a snake go up into a blockage.
Any advise would be appreciated.
Jon
Jon
