Venting Bathroom - Is my way a good way?
fjacky32
I want to vent my bathroom. If I vent through the ceiling to the attic and out the side of my house I'll have to travel over 20-25 feet. I think that's too far, and I also have very limited space in my attic. Here is what I want to do. I have an inline duct fan, which is powerful enough to vent the air. I want to directly vent it out the side of my house. It is located on top of the bathroom window. The fan is approx 6 inches long and it will fit perfectly. I will wire it to my light which is very close. I will make sure its done safely. On the outside I will put a dryer vent on the fan with flaps on it so critters and the cold wont come in. It seems to be easy enough, am I overlooking anything here?
Your thoughts? (see attachments for my materials)
P.S. I live in Ontario, Canada, so the winters can be quite cold...
Ian Gills said:
It sounds great to me since you are venting directly to the outside. But how will you cut through the brick wall and where will you run the wires?
I am so scared about how and where to vent i.e. cutting holes in either the roof or the wall that I am resigned to continue using the most simple and legal alternative.....opening the window.
It's aluminum siding. I'm just really worried about the bathroom being real cold in the winter. I was hoping the outside vent with flaps would help
Check your local codes. Down here if you vent through the side of a building you must be 10' above average ground level and 10' from the lot line. Plus making provisions to keep birds/rodents out as well.
My suspicion is that the duct fan you have is going to move much more air than you will want to push outside your house during winter, and also that it is noisy.
I would suggest looking around for something more substantial than a dryer vent, and possibly even one that is motorized so it can pull the seal-together louvers tight shut when not in use. Otherwise, pennies (or maybe even nickels) will be continually floating away out into the cold night sky ...
Ya, that's my only real worry. But again, wouldn't cold air also come in if I vented through the roof?
With properly insulated pipe and correct penetrations he's not gonna lose heat through a plumbing vent.
It won't be insulated. It's just going through the wall. 6 inches. Of course I'll spray some foam insulation around the inline duct fan, but Ill have a regular indoor vent on the inside and a dryer louvre vent on the outside. (I have attachments in my original post)
Guess it's not gonna work.
Back to the drawing board I guess
Understood, but he is talking about a dryer vent going through the wall just above the bathroom window.
I could be wrong, but I think not. Rather, hot air would rise ... and a balanced damper might help to slow that down when the fan is not running.
duct
I am a bit confused about how you would install the fan. If you can go through the side wall, why not use a wall mounted vent/fan unit instead of monkeying with dryer vents and inline blowers?
I live in Ontario, Canada and I can't find one over 50cfm. And the wall mount fans seem way more pricey.
Heat Loss
Ok, Maybe I'm a little out of my league. I'm a firefighter, and if you've ever seen the heat loss from any vent (dryer, bathroom, kitchen hood,...) through an infra-red vision camera on a chilly night, you would see the market for a million dollars.
I'd say that if you vent out, over the window, you'd be fine, just try to get the best insulated external vent cover available
