Question about moving stove line to dryer.
enviroko
We currently have an electric stove and a gas dryer but we are in the process of installing a gas stove and electric dryer. Here is our situation...
The hot wire that feeds the stove looks like it says 8/3 (old and hard to read).
The hot wire first connects to a junction box then out to the stove with a 6/3 wire.
There is already a 10/3 wire ran to the dryer that was disconnected by someone prior to me buying the house.
Question: Can I disconnect the old hot (8/3) from the junction box and connect that to the 10/3 wire to feed the dryer?
you need to have a professianal plumber check out your gas switch over
a gas dryer is rated at 38,000 btu's a full size gas range is rated at 65,000 btu's gas is "NOT" sized to pressure, but to volume not the right size gas line means you will be sterving a gas appliance some where in the house "which"
could cause a "CARBON MOXIDE"!!! problem down the road when the furnice and stove, and
water heater is all running at the same time!!:( :(
like when you have the whole family over for thinksgiving, or christmas
JERRYMAC MASTERPLUMBER:)
jwelectric said:
Yes but be sure to change the breaker to a 30
Unfortunately I still have a fuse box (changing within six months hopefully) and I was unable to find a 30 amp to fit. 35 was the closest. The fuse that was used for the stove was a NON-45 class K5. Can that be replaced with a 30 amp fuse?
I do have 3/4" pipe going all the way to the flex line of the stove but sounds like that doesn't guarantee 65,000 btu's. Is that correct?
