A 60W equivalent CFB actually draws probably in the 15W range to put out the same amount of lumens. If you actually got 60W CFB, they would be significantly brighter than what is there. So, going with 60W equivalent bulbs, you'd save about 3/4 of th epower, and they would last probably 5x longer. Note, check the color temperature of those you buy...there can be a signficant difference in the color they output, plus, they do take a few minutes to reach that full brightness and if the building is not heated part of the time, some of them won't light if it is too cold. Most (but not all) cannot be used on a dimmer, so keep that in mind as well.
