Jacuzzi tub main switch.
Debbie Pounders
We had an inspector come out to our home, and he got the Jacuzzi Tub working. But now, the switch on the tub will not come on. I think there may be a disconnection between the master switch and the switch on the tub.
Where is the master switch on the tub? Is it on the pump? I have already tried the breaker switch--did not phase it.
Thank you,
Debbie
If this is an air switch, there is a plastic hose on the back of the switch that might have fallen off.
tub
Your GFCI the tub is plugged into could also have tripped. If so, and it happened because the pump was started, it could indicate an electical problem.
