Kohler lav cartridges... slow leaks?
David Meiland
General Contractor
Friday Harbor, Washington
www.facebook.com
We recently did a bath remodel and the lav faucet seems to have a very slow drip (so slow it's almost not happening, but the drain stopper is wet, and there is usually a drip hanging from the aerator). This appears to be from both the hot and cold sides, which I checked by shutting off one angle stop and then the other, allowing a few hours each to see if that solved the problem. The faucet is a Kohler Forte widespread, with quarter turn cartridges that I think of as "butterfly" style. It looks like the cartridge is a 77005 or 77006.
Anyone familiar with these? What's the chances of two of them not quite working? If one didn't work, I'd assume maybe a piece of grit in there that's allowing the drip... but both of them? I'll probably call for new cartridges and ask my plumber to change them, but is there another possibility I'm not thinking of?
I installed the Forte widespread about 6 months ago. I had a similar leak on the hot side only. It was barely noticeable except for the stopper being wet. Maybe a drop every hour or so.
I contacted Kohler and they sent me both cartridges at no charge. They recommended changing both even though only one leaked. Maybe there was a design issue?
I would suggest getting the new cartridges from Kohler and you should be fine.
Good luck!
Just to clarity, my faucet leaked from the moment I put it in also. I tried flushing it, turning it on and off rapidly, took out the cartridge and did a visual check, etc., nothing worked.
Just one of those things. However, you got the double whammy.
Again, good luck with the repair.
