OscarG
- Messages
- 17
- Reaction score
- 0
- Points
- 0
This is my second attempt at major DWV project so I am looking for advice on my design. This is for adding bath, kitchen and compact washer to second floor "loft" space over an existing shop area. Building was built about 15 years ago and never finished. Now looking to make it livable for weekend/vacation get-away. There is no other plumbing in the building.
Floor plan is
DWV Stack is moved to the east wall (where I discovered I had space above a solid beam to get "under" the second floor wall) of plan where VIEW is marked. Design goal was to keep all west to east horizontal drain lines above or very close to joists. All 2" drains achieve this goal except where they enter stack which is OK. W.C. drops below joists but is only a short run to stack. This was necessary to allow 3" vent above the San-Tee w/L&R Entry to angle 45 degree to get into wall cavity. 3" vent above this fitting is dry! New stack plan is
(PDF drawings deleted)
A is 2" drain from washer stand pipe which is vented at far end.
B is 3" drain from W.C. about 14" away.
C is 2" drain from shower less than 5' away from P-trap at shower pan. No venting except 3" stack.
D is 2" drain from lavatory and kitchen sink. Each has its own vent since kitchen sink is about 6' upstream from lavatory.
From what I have read 2" DWV horizontal can handle 8 units. C+D, where they enter stack are 2 units (shower), 1 uint (lav), 2 units (kit sink) TOTAL 5 units (and 2 of them from shower only go a few inches into stack).
There is 3" vent to attic/roof above San-Tee w/L&R Inlet (3x3x3x2x2). Dry above. Stack feeds down to horizontal run going south to exit from building, through concrete foundation. (The exit pipe was preinstalled before they cast foundation.)
Would appreciate expert/experienced comments and suggestions on this REVISED design.
One other note, this building is in western NY state, outside of "big" city code requirements. I had received a comment about some inspectors rejecting the San-Tee w/L&R Inputs but I don't think this will be a problem.
One other note, this has been a great learning experience!
Thanks in advance!
Floor plan is
Thanks in advance!
