I have a four zone sprinkler system. Zone 1 does not shut off. It also sounds as if water is running at the control box in the ground while none of the sprinklers are on.
When zone 1 continues running I am unable to shut it off at the timer unless I start a "Test" and then stop the test while those sprinklers (zone 1) are running.
What can cause sprinklers to keep running? Only 10 or 12 things?
Much appreciation.
JT
Much appreciation.
JT
