During some very cold weather about a month ago, I temporarily lost water flow, but was able to quickly restore it by taking a hair dryer to the inlet pipe just before the pressure gauge and pressure switch. When the water flow restarted, however, the readings on the pressure gauge were increased by about 50 psi. That is, instead of the usual 30/50 on/off, the gauge now reads about 80/100 on/off. There doesn't seem to have been any change in water pressure or system operation, however, until today, when I'm noticing that water flow sometimes stops completely for a second or 2, then resumes as normal.
I'm thinking the pressure gauge was probably damaged and needs to be replaced. Does this sound right to you and, if yes, could I have some quick instructions on how to do this? I can obviously see that a nut needs to be loosened to remove the gauge, but what else should be done first. e.g., do I need to turn power to the well pump off, do I have to drain the pressure tank, etc.?
Also, what do you make of the brief pauses in water flow I described? Thanks! Gary
