Those size tanks are way smaller than I would use on a system without a CSV. You might get away with it if you never use water outside the house like with a garden hose or sprinkler. If you run a 5 GPM garden hose or sprinkler, it would cause your pump to run two minutes and be off for two minutes. There are 1440 minutes in a day so, if you leave the sprinkler running your pump would cycle on and off 360 times a day. That number really adds up over the life of the pump and causes your pump system to fail much too soon.
