Metal straps on ABS pipe?
David Meiland
General Contractor
Friday Harbor, Washington
www.facebook.com
I bought a couple of boxes of 2" and 3" C-shaped pipe straps from Keller. When I opened them they turned out to be galv steel. I'm going to be running ABS drains and am not sure that metal straps are OK on plastic pipe. The salesman I buy from is generally right on as far as what he sends out to me, so I assume that's what he's sending everyone. What are pros using?
The metal straps will be fine as long as when you hang the pipe it doesn't pull the pipe up from the drain angle.
