Swanstone Shower Pan Creaking
mikez68
We installed a Swanstone shower pan and now when you stand on it, there is some play in some spots of the pan and a creaking sound - like part of the underside of the pan is rubbing against something. We installed it over a new plywood sub-floor, and since the floor wasn't perfectly level we poured some Jiff-Set self-leveling floor compound down and installed the base on top of that. We then screwed the base flanges to the studs to keep it in place.
is there anything we can do to stop the creaking?
Thanks,
Mike
Are the walls up and tiled yet? If not, take the pan out and use some sand mix mortar under the pan to ensure all of the nooks and crannies are filled and supported. Mix it kind of wet and smush the pan down so it is level. If the walls are up, you may have to live with it. The use of the mortar mix under the pan is not optional if you want a good result (no creaks, deflection), in my limited experience. My unprofessional opinion.
And, don't walk in or move the pan until the concrete has set.
Walls are up but not tiled yet, so we may be able to still fix it. Depends on whether or not I can remove the drain. I have to check with my plumber, it may be cemented in. Thanks.
Thought I would re-open this one since I'm doing the same thing.
On another forum a fella said to mix it DRY (not wetter)...
It is my understanding that you still want it to rest on the subfloor, correct? The mortar is only there to fill and areas where it can't rest on the subfloor. Correct?
In other words, the goal here is to smoosh it down to the subfloor, through the motar?
Thanks for clearing it up.
Pete
Smush it so it is level...if that is to the subfloor, good, if not, it's still okay if you have full support.
