Have a new Flexcon Flexlite FL7 (16" x 34") that the factory says must be installed vertical; driller wants to place it horizontal. It will be in constant pressure as it is being used with a new CSV1A w/a 40/60.
http://www.flexconind.com/pdf/fl_features.pdf
This is to be buried and is replacing a waterlogged WX250UG.
Besides recommending other brands (this is what he uses-period) is there a detriment to mounting it horixontal?
If I mount it vertical I can place an irrigation contol box over the top to get access to the Schraeder vs running a poly hose if it is mounted horizontal.
Thanks....
Thanks....
