Thermostatic Valve Setup Help
Kaveman42
los angeles
Our plumber installed a Thermostatic Temp Control Valve for our custom shower which has three pressure valves controlling the showerhead, hand held shower, and rain shower. I noticed that from the Therm Valve he used both outlets. One was for the rain shower and the bottom for the showerhead and hand held. The website say's that the bottom valve is for a tub spout only. Is there a reason for not using the bottom valve when using pressure control valves? I understand if you use a divertor that the bottom valve can build pressure if using something that cannot handle the flow and cause it to flow from the other outlets. Should we ask him to cap the bottom outlet and reroute the pipes to the top outlet?
Don't think it will make much of any difference. It becomes a much bigger issue if you're using a tub mounted diverter, but with individual shutoffs, probably not an issue. FWIW, some thermostatic valves require a shutoff before it, not after it. If yours doesn't care, then it's a non-issue.
Thermostatic Valve Setup Help - California Water Conservation
Kaveman I'm helping a client in California that lives in Malibu Beach and he tells me that California has water conversation codes.
From what I understand you can only have one fixture on at a time. Your plumber might have rigged up your system to comply with this code. This is why it might differ from what is listed.
Can not be sure 100% but this might be a reason.
JW
valve
If the valve is designed to be used with a "twin ell" for the diverter spout, then it makes no difference how he pipes it. If it was designed to just use a diverter spout, then the bottom opening has a greater flow rate than the top one.
HJ I just looked at this PDF and it appears the system needs a flow valve(s) as well.
There is openings for Hot and Cold (Left and Right) and two outputs top and bottom.
I would suspect he needs this Thermostatic Control valve piped to a three way diverter to meet local code.
