DonL
Using a Valve like that will only throttle the volume and not the pressure.
Some Valves want to be opened or closed, and may leak in a different position.
Use whatever works for you.
You only need 40-50 psi for your house, 60 is nice, so a Pressure regulator is what you need to fix your problem and be done with it.
Have Fun.
Have Fun.
