Shower stall replacement
brussell222
Easton Md
I want to replace my shower stall. My current shower unit measures 46" wide. I can only find 48" units. I'm not sure I can find 2 extra inches when I remove the old unit. Has anybody run into a similar situation
any ideas?
A shower can be made any size.
If you want to buy a shower stall from a store, you have to chose from what they sell.
If you would consider going a little smaller,you might want to try showers by Maax.
I'm pretty sure that shower kits are measured the same way tubs are...from the rough-opening. You sure it's 46"? That being said, you can make or have made a tiled shower in any size as you wish (as long as it's above the code minimum 30x30" in the USA).
