rob742
It is fairly common to reverse the wire after pulling the pump. By reverse, I mean top to bottom.
The new pump may be moving more GPM than the old one was and that in and of itself could churn up some crud. Start slow and increase the flow on your outside hosebibs until it runs clear.
hi LLigetfa, Thanks for your reply. I dont follow what you meant about reversing the wire, The pump has a 240volt single phase motor. Are you referring to this. The original motor had a red ,black and green ground wire. The new motor had 2 black wires and the green ground. Is your reference to these wires on the motor. Since the plumber cut about 15 feet of hose and wire off the original pump,the new pump is 15 feet higher from the bottom of the well. I would think it is further away from the sludge at the bottom of the well. I did notice the 280 foot hose that connects to the pump was coated with iron rust, But this had been this way for some time and I never had sediment and rusty water before. I will do as you suggested and turn on the outside hose bib and hope it runs clear. I am going to shock treat the well with chlorine tablets. BuT i am thinking I should wait until this issue is resolved first.
Thanks for your Ideas Rob
Cacher is right, it will go away, but it is difficult to predict how long it will take. Every well is different.
What happens is that when the water rises and falls during the wells usage, oxidation is created. This oxidation is disturbed when the pump is pulled and replaced. Having the pump hung on poly pipe or hose can scrape or disturb even more stuff due the curl in the pipe. Adding chlorine will further oxidize the iron making it seem even worse. I don't know about Pa law & code, but state law in Ct requires the installer to chlorinate the well after servicing it. Just imagine all the bacteria that 280' of pipe picked laying on the ground!!!!
Cutting the bottom of the wire off tells me the pump didn't have the proper protection to keep it from torquing when it started and stopped. Reversing the wire is a half assed way of doing the job, but I suppose there are some out there who do it......
I plan on shocking the well but I need this rust and sediment to go away first.
You mean the plumber didn't chlorinate the well when he was done?
Don't be surprised if the water turns rusty looking when you "shock" the well.
