Toilet Rough In for the Furture
Chefwong
District of Columbia
I think I'm leaning on the UltramMax II but may go with the Vespin. Need to see them in person...
However, the walls are going to be tiles so I would like to RO the water supply for a skirted toilet should I do that in the future.
Based on past posts , 5.5 off center seems to be the sweet spot.
Height ?
Height ?
It's all diagramed in the spec sheet...use those dimensions, and you are sure it will work. While you can get by with less, just use the spec sheet, readily available at the Toto website.
If you are roughing for a skirted bowl, then rough at 7" or 8"
6" will work, but it's snug.
The non-skirted can be as tight as 3"
So........between 6 and 8 is good.
Or anywhere that you don't hit the back of the bowl.
